× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Router for wireless broadband sim
AnthonyGirdler
Follower
Hi,
I'm looking for a decent router compatible with wireless broadband that will take a sim card .
I need it so I can use QoS to prioritise my device.
I currently have a Huawei b525. It doesn't allow QoS.
Message 1 of 2
Netduma_Alex
NetDuma Partner
Re: Router for wireless broadband sim
Unfortunately none of the Nighthawk Pro Gaming routers are SIM card compatible.
If you could get a SIM card modem, you could connect that to a Nighthawk Pro Gaming router. For example, you could buy a NETGEAR LB2120 and connect an XR500 to the LAN port.
Given the relative unreliability of cellular networks (in terms of ping), you would likely have to set some rather agressive QoS.
Message 2 of 2
Discussion stats
  • 1 reply
  • 954 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
