Reply
Highlighted
Tutor
SETUP HELP
Hi i have just bought the xr 500 &a netgear modem, I am setting them both up and dont know whether i should have the modem set to router&modem mode or modem mode? The manual suggests in R&M mode i couldnt use advamced features on the xr500 so i guess i should use modem only mode?
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 3
Highlighted
Guru
Re: SETUP HELP
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Modem-router-setup/td-p/1715063/jump-t...
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
NetDuma Partner
Re: SETUP HELP
Optimal setup is modem mode as that should ensure Open NAT. More info here: http://support.netduma.com/en/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-o...
Message 3 of 3
Discussion stats
  • 2 replies
  • 399 views
  • 0 kudos
  • 3 in conversation
Announcements
