Reply
Settings keep changing
Consumer0129383
Luminary
In the Geo-Filter settings like kilometers/miles and zoom factor keep resetting. Also, can anyone tell me why I am connecting to a server in the UK?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 13
Guru
Re: Settings keep changing
What FW version are you using?
What Browser are you using? Does this happen with other browsers?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 13
Consumer0129383
Luminary
V2.3.2.56 and Safari. I don't use any other browser.
Message 3 of 13
Guru
Try Firefox or Opera and see.
Message 4 of 13
Consumer0129383
Luminary
Settings still changed. What about the server in the UK? Why am I constantly pinging that one server?
Message 5 of 13
Guru
Message 6 of 13
Consumer0129383
Luminary
Google GFRG200. Yes, on both devices.
Message 7 of 13
Guru
Is the modem in modem mode only or in router mode?
If router mode, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Message 8 of 13
Consumer0129383
Luminary
Are you trolling me?
Message 9 of 13
Guru
These are valid questons to help narrow down this issue. Please give feed back to the question. A router infront of the XR router is not recommended and could be a factor in this.
If you don't think we can help you then you can open a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
Message 10 of 13
Consumer0129383
Luminary
I have Google Fiber which means I am using their network box as a modem and the XR500 as a router. The fiberbox doesn't have a bridge mode so I have terminated its wifi functionality and DMZ's the XR500. Although prior to this I eliminated the Fiberbox all together but the upload speed somehow was adversely effected. So, now I'm back to this. The issue(s) I brought up today have to do with my settings always seeming to change on me with in the geo filter; i.e, kilometers/miles and the zoom factor. The other issue is that I always seem to ping a particular server in the UK. The NG and GF routers have both been reset to factory settings more than once and I seem to still be experiencing issues.
Message 11 of 13
Guru
Ok, thank you for clairifying this.
One thing you can try to see if this problem continues, downgrade FW to v32  and factory reset. Setup from scratch and let us know the results...
Message 12 of 13
Netduma-Fraser
NetDuma Partner
Is your browser set to save/allow cookies? As that is what controls settings like this on the router. Also are you accessing the router via HTTP? Make sure you are if not. That server in the UK is an authentication server required for online play. It is not the game server you are playing on and will not affect your game ping. It's normal to see this.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 982 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
