× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Should I wait for the next nighthawk the current one doesn't specify if it's Wi-Fi 6 capable
bacin87
Tutor
I see that new nighthawk mesh Wi-Fi router that isn't setup for gaming is a Wi-Fi 6 device but the gaming router the xr700 isn't will it be software-enabled or is there a hardware restriction I'm trying to decide on my next router
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: Should I wait for the next nighthawk the current one doesn't specify if it's Wi-Fi 6 capable
It isn't something that can be updated with software, it has to be hardware. Have you got WiFi 6 supported devices that could really take advantage of WiFi 6?
Message 2 of 2
Discussion stats
  • 1 reply
  • 555 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
