× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Slow DumaOs
wait_i-m_low
Guide
Slow DumaOs
Hey!
I think my DumaOs is pretty slow, don’t know why.
Although the Geofilter isn’t working in the right way. I get players from outside my Geofilter even the filter mode is activated.
When I’m in a party with friends they are not showed in the geofilter( maybe that’s normal)
So for that reason I don’t know whom I allow to connect when I search for games in PvP ..
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 9
Guru
Re: Slow DumaOs
What version of FW are you using?
What browser are you using? Happen in FF or Opera?
Message 2 of 9
wait_i-m_low
Guide
Re: Slow DumaOs
The last firmware that is available.
I test it on pc with ff and ie and on my Mac with safari
Message 3 of 9
Guru
Re: Slow DumaOs
Try a factory reset on the XR and setup from scratch.
Clear ALL browser caches, then open the routers web page.
Message 4 of 9
wait_i-m_low
Guide
Re: Slow DumaOs
Okay i will try that.
I already did a factory reset but didn’t delete the browser
Message 5 of 9
Guru
Re: Slow DumaOs
Let us know if it helps...I Think NG is aware of the slow down.
Message 6 of 9
Netduma_Jack
NetDuma Partner
Re: Slow DumaOs
Which devices did you add to the Geo-Filter? If you could share screenshots of the Geo-Filter page that'd be very helpful, as you have abnormal behaviour here.
Hopefully a factory reset solved your problem anyway
Message 7 of 9
wait_i-m_low
Guide
Re: Slow DumaOs
Sorry guys,
Im on a Business trip till Friday.
I will check everything at the Weekend.
Thanks for the replies!
Message 8 of 9
Guru
Re: Slow DumaOs
Smiley Wink
Message 9 of 9
Discussion stats
  • 8 replies
  • 2466 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
