× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Slow download speed
Compoza_
Luminary
Slow download speed
Hi! I have internet speed 500 mg download and 100 mb upload and I get lower download speed on router xr300 compared to my ISP's router. I get 450-500 mb download speed with my ISP's router, and I get 300 mb download speed on xr300. I haven't done bridge mode between them. I have the latest firmware btw. Using wired cable.
I really need help!
Regards
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 8
Accepted Solutions
Netduma-Liam
NetDuma Partner
Re: Slow download speed
Do you have QoS enabled? Do your speeds return to full when you fully disable QoS from the menu in Congestion Control?
Message 2 of 8
All Replies
Netduma-Liam
NetDuma Partner
Message 2 of 8
Compoza_
Luminary
Hi! The current DumaOS I have doesn't have the Congestion Control. But I have disabled "Share Excess" and still doesn't work.
Message 3 of 8
Compoza_
Luminary
Hi again! I found the menu and have disabled the QoS and it works! Just now I got 490 mb download speed 🙂 But what happens when it is disabled?
Message 4 of 8
Netduma-Liam
NetDuma Partner
Good to hear! Everything is working properly then. QoS throttles your bandwidth speed to ensure it can control traffic on your network, if you run a connection benchmark with QoS enabled you should still see the speedtest shows your full speeds.
Message 5 of 8
Xcel
Apprentice
This is not normal operation. With QOS enabled and with congestion control at 100%, you should be getting full speeds. There is something wrong with QOS as I am having the same issue
Message 6 of 8
Netduma-Fraser
NetDuma Partner
QoS is still active in that scenario so depending on what is set it can differ
Message 7 of 8
Compoza_
Luminary
Hi, I have already accepted the solution.
Model: XR500|Nighthawk Pro Gaming Router
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2693 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
