Divan
Nov 03, 2020Aspirant
Slow internet speeds on XR300
I recently got a nighthawk xr300 router. I have a line that runs 200mbps up and down and when doing speedtests on the nighthawk app it shows that I have 200+ mbps up and down, but for some reason I cannot get my PS4 to run on speeds higher than 20mbps and I keep getting lag spikes while playing games. Can anyone assist me on how to fix this?
- Netduma-FraserNetDuma PartnerConsole speed tests can be quite inaccurate. What are your QoS and Geo-Filter settings?
- DivanAspirant
I know that console speed tests are not the most reliable, but when I connected my old router again I had speed tests showing between 150-200+ mbps.
I have geo filtering disabled. QoS settings is setup at 200mbps with the anti-bufferbloat settings on 70% and 'when high priority traffic detected'.
So to me it seems that the router is restricting the internet speed and bandwidth to my console because with the normal router everything seems fine.
- Netduma-FraserNetDuma PartnerYou should use the Geo-Filter to help lower your ping by forcing the closest servers. It is most likely Traffic Prioritization that is impacting the speeds as it's prioritizing the game packets over the speed test. You do have plenty for gaming.
