× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Slow local traffic with XR500
WindfallNL
Setup : internet modem -> router (XR500) -> computer 'M' -> VM on 'M'. VM runs web server. Web server has a 5 MB gzipped page for index.html. A domain name 'D' is mapped to the WAN address of the modem.
Now If I browse to 'D's index.html locally, it takes a pathetic 50 seconds (100 KB/sec according to a separate wget). If I browse from a remote location, it's in in 5 seconds !
What up ? This started when I changed my old Netgear router (JNR3000) to the new one (XR500). QOS switched OFF.
This is a mystery. How can local traffic (which never even gets on Internet in this case) be slower than remote ?
Any clues ?
Thanks.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 8
Guru
Re: Slow local traffic with XR500
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 8
Netduma-Fraser
NetDuma Partner
How are you accessing the local site specifically? Are you using HTTPS? If so is it faster using HTTP?
Message 3 of 8
WindfallNL
Firmware V2.3.2.40
The modem is a Ziggo 'Connect box', no doubt it is rebadged but I can't find relevant info. They used to be Zyxel brand modems.
Message 4 of 8
WindfallNL
I simply browse the domain name with Firefox. It's all HTTPS. If HTTP is used, it is automatically redirected to HTTPS.
Message 5 of 8
Netduma-Fraser
NetDuma Partner
That could be why, is there a way you could disable HTTPS briefly for the server and check with HTTP to see if its faster?
Message 6 of 8
WindfallNL
I removed the 301 response for HTTP requests (I actually wrote this server myself), restarted the server and explicitly browsed HTTP. No difference.
I'm not surprised, because, as I reported in my original message, browsing from somewhere offsite is fast, whereas browsing onsite to the same thing is not.
This cannot be anything but a routing issue (or something along the route doing deep packet inspection really inefficiently), and the XR500 remains my main suspect.
Message 7 of 8
Netduma-Fraser
NetDuma Partner
Thanks for trying, with QoS completely disabled it won't be interacting with any packets. This might be one to contact Netgear directly about as they may have seen this on their non DumaOS routers http://support.netgear.com/
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1270 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
