- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slower Speed on Ethernet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just installed the router and have noticed a problem. When running speed test from my wired PC, the speed is around 30 download. I currently have 100 from spectrum. Before switching the router out it was over 100, and now not close. Have reset the modem, have reset the router, have cleared my dns and arp cache on the pc. If i do a speed test on my phone, it comes up and shows 110, like it should. So not sure why the ethernet connection is slower.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slower Speed on Ethernet
First set your bandwidth to your expected speeds in Anti-Bufferbloat advanced options. Then set Anti-Bufferbloat to 'Never'.
Reset distribution on Bandwidth Allocation for both download & upload. Also make sure share excess for both download & upload on Bandwidth Allocation are checked (also in advanced options)
Then remove/disable any rules for Traffic Prioritization.
Redo the Speedtest . If you don't get your full speeds after that then disable QoS completely within Anti-Bufferbloat's settings and try again.
If it’s still slow, try a different Ethernet cable.
If the problem still persists, please contact Netgear’s 24/7 support and they will help: https://www.netgear.com/support/contact.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried the above suggestions and speed test is still lower, between 30 and 40. will see about contacting support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
