× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Source video issues
Thawk21
Source video issues
I moved to a new house fiber internet. 1gb up and down. My speeds seem fine but for some reason when watching twitch or YouTube, anything over 480p quality it starts to buffer. This happens from my pc that is hard wired and from my phone that is on wireless. Any ideas what could cause this?
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 6
Netduma-Fraser
NetDuma Partner
Re: Source video issues
What are your QoS settings?
Message 2 of 6
Thawk21
I haven't changed anything. So whatever the defaults are out of the box.
Message 3 of 6
Netduma-Fraser
NetDuma Partner
Have you enabled the Geo-Filter? Are you using Smart Connect for wifi? If so disable and connect to 5GHz
Message 4 of 6
Thawk21
I do have smart connect turned off and am using 5ghz and I've tried hard wiring and still happens.
Message 5 of 6
Netduma_Jack
NetDuma Partner
The best step here is to isolate where the issue is. What happens if you connect these devices to your modem, does the issue continue?
If it does, then there's probably an overall problem with the line.
If they're fine, then there's likely to be an issue with the router.
Let us know what you find. Thanks.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1760 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
