Reply
Specific R8500 issues needing a NEW Router???
lbelardinelli
My R8500 issues
I own a Netgear R8500, Netgear EX700, and FS726TP switch and I am thinking of getting a new router because of some R8500 issues. The issues are:
1) Limit of fixed IP addresses you can do
2) Can no longer change name of item in the attached list
My uses are as follows:
1) I use the 10.0.0.0 to 10.0.0.200 IP range in a 2400 sq ft, one level, home
2) I have 18 directly attached devices (printers, computers, TVs and AV equipment) via a netgear managed FS726TP smart switch (Note: my home is completely wired for 25 ports)
3) I also have MANY wireless devices attached to 5Ghz (like phones, laptops and tablets)
4) I also have MANY wireless devices attached 2.4Ghz (like 25 smart home devices)
As of now, I can no longer fix the IP addresses of my smart home devices (I keep them separated for control sake) and for some reason
my R8500 will no longer allow me to rename my devices.  I am VERY unhappy with this situation. I AM thinking of buying the new  Wi-Fi 6 Netgear
is offering soon and I wanted to know if it will help my situation.
Sincerely, Leo Belardinelli (lbelardinelli@hotmail.com)
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 2
Guru
Re: Specific R8500 issues needing a NEW Router???
Please post about this in the Nighthawk routers forum:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 524 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
