× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Sub domain of a webpage won't load properly
Sleepy_one
Howdy all,
I'm trying to access the webpage https://us.shop.battle.net/en-us .  When it loads, I get a blue screen, and it won't load any further.
I originally used my ISP's DNS, but swapped over to google (8.8.8.8 & 8.8.4.4) but this does not fix the issue.  I hooked up my computer directly into the cable modem (AC1000), and the page loaded perfectly.
I have NO pages blocked and cannot find anything in the settings that could cause this.
Any suggestions?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Sleepy_one
Re: Sub domain of a webpage won't load properly
correction, my router is a CM1000.
Message 2 of 5
Guru
Try a different browser?
That site works for me on Mac and Opera.
Please post this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Message 3 of 5
Sleepy_one
Different browser does not work.
Message 4 of 5
Guru
Factory reset the router and set up from scratch. Walk thru the setup wizard of the router and let it set up the connection.
Besure to clear any browser caches. Then try the site after this.
Try a different PC to see if same thing happens there.
Might set some custom DNS on the router as well, like cloudfare and quad9.
Message 5 of 5
Discussion stats
  • 4 replies
  • 1029 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
