Reply
Highlighted
Traffic Prioritization multiple xbox's
I have 2 xbox's in my house. What do you recommend the settings do be so that when my son is playing his it does not take priority?(which it should not) Im thinking
add device-my xbox-advanced rules-1to 65535 tcpand udp. Does this setting make since for xbox one x
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 2
Accepted Solutions
Highlighted
NetDuma Partner
Re: Traffic Prioritization multiple xbox's
Gaming barely uses bandwidth so there would be absolutely no issues prioritizing them both. However to do what you want disable DumaOS Classified Games and simply add your Xbox with the Games Console service.
Message 2 of 2
All Replies
Highlighted
NetDuma Partner
Message 2 of 2
Discussion stats
  • 1 reply
  • 1668 views
  • 1 kudo
  • 2 in conversation
Announcements
