- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgraded from netduma to xr500 for faster speeds ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be preferred to have the XR wifi on the main level however if it has to be in the basement, then disable it's wifi radios and use the R8000s wifi in AP mode if it can be up on the main level. I would disable the X4 upstairs as well and see if the wifi from the R8000 in AP mode is sufficient for wifi upstairs.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgraded from netduma to xr500 for faster speeds ...
Speed testings wired with the cable modem first. Then wired with the XR router while nothing else is connected?
Did you walk thru the setup wizard when connecting it to the cable modem and you power cycled the cable modem as well?
What FW version is loaded on the XR500?
The max you'll see out of any 1G supporting router and capable PC is 900Mb + or -.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you're using QoS you'll remember from the R1 that it'll throttle your speeds so after making sure you've entered the correct speeds make sure Anti-Bufferbloat is set to never and 100% then run the wired speed test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
MAC addresses should not be the same on any network.
If you have the R8000 is AP mode, then you should disable the wifi radios ON the XR router unless you have a good distance between the XR and R router, 30-40 feet to start and you use manual channels on each farthest channels away from each other on 2.4Ghz and 5Ghz.
@EurynomeStolas wrote:
My biggest issue is that the internet works fine. Then WiFi keeps getting dropped and the wife is 😡. I was wondering if I have a r8000 in ap mode then the xr500 has to use the same MAC address as the r8000 does that mess with the network that they have the same MAC address? I just want to get this working. I get home and run me run the setup wizard and I will have internet on wired devices but not WiFi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
that is exactly what i did and ewverything seems to be running good for now. i will let you know if something comes up. i am going to be making a new post with a question about the devices on the device manager.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear, Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Furry for the great advice. Glad you got it sorted OP
