× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Using Ethernet Ports without using Internet Ports
Kyle_Cortes
I was wondering if there was anyway to use the Ethernet ports, without using the Internet port.
I want to use my XR500 to only use the ethernet on my PC.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Guru
Re: Using Ethernet Ports without using Internet Ports
I guess I'm a bit confused by what you're asking. You don't want the router connected to the internet? you just want to be able to use the ethernet ports to act as a switch? Why not just buy a switch?
Message 2 of 4
Kyle_Cortes
What kind of switch?
Message 3 of 4
Guru
Message 4 of 4
Discussion stats
  • 3 replies
  • 825 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
