Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wan setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-28
03:38 AM
2019-06-28
03:38 AM
Wan setup
in WAN do I put the number I assighned my xbox1x if I want if I want it a default DMZ server?
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-28
08:40 AM
2019-06-28
08:40 AM
Re: Wan setup
You can however it's not needed. You only need uPnP enabled on the XR router and connect the xbox to the router via wifi or wired. Wired is preferred. Disable Instant ON on the xbox as well. If the xbox isn't fully connecting, press the front power button on the xbox until it shuts off. Then turn it back on. This will clear out any bad networking cached configurations.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-29
05:28 AM
2019-06-29
05:28 AM
Re: Wan setup
As above UPnP should allow your Xbox to get an open NAT in the console network settings. I would advise you read this guide on NAT first but to answer your question you would put the Xbox IP as shown by the device manager in the DMZ in WAN Settings but this shouldn't be needed unless you've tried all other steps and they don't work. http://support.netduma.com/en/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-o...
Message 3 of 3
Announcements
