× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WeMo switches have to be reconfigured when unplugged
Xenos8
Apprentice
I have an XR 500 on the latest firmware (V2.3.2.40 +patch) and two WeMo plugs and a wired switch.  If I unplug a WeMo or we lose power I have to go the through the WeMo setup all over again.  The odd part is I can see all three in the XR500 device list as if they are connected.  However they disappear from the WeMo app and have to be setup from scratch each time.  This never happened before with my previous non-NetGear router.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: WeMo switches have to be reconfigured when unplugged
I would assume this is because the IP they had has been released by DHCP upon disconnection/being unplugged. Give the WeMo plugs static/reserved IP address in Settings > LAN Setup, apply then reboot the router and see if it happens again afterwards.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 937 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
