- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What solved my xr300 problems where the speeds were limited or reduced
- Mark as New
- Bookmark
- Subscribe
- Permalink
I upgraded my ISP connection from 250mbit to 1gbit.
My XR300 started only delivering 100mbit - despite no router settings changes, and no physical changes to the cabling.
I tested the internet connection directly and recieved ~= 600mbit, and confirmed all my router connections were 1000mbit full duplex.
After many reboots, recabling etc and nothing working (toggling QoS etc), I stumbled on a fix.
I put the XR300 in VLAN/Bridge mode, waited for the reboot, then turned VLAN/Bridge off and waited for the reboot.
Now I'm getting similar speed to a direct connection ~= 600mbit.
It makes no sense, but it fixed the problem.
Hopefully Duma 3 will make this router a little more reliable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What solved my xr300 problems where the speeds were limited or reduced
That's interesting, thanks for posting your solution though, that's really helpful!
Let us know if you have any further issues or questions!
