× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
What subnet mask should I use for LAN?
That_GamerYT
Apprentice
I have my XR500's subnet mask for LAN at 255.255.0.0, but do I need to change it or should I leave it like that? What happens if I change it to 255.255.255.255?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: What subnet mask should I use for LAN?
Did you change that? It's 255.255.255.0 by default. While that is fine to do so unless you have 65k+ devices to connect to the router, which I assume you don't then that is unnecessary. However, changing to 255.255.255.255 is way too restrictive only allowing for 1 IP. I would highly recommend you leave it at the default or what it is now - these options will not give you a better game experience.
Message 2 of 2
All Replies
Netduma-Fraser
NetDuma Partner
Message 2 of 2
Discussion stats
  • 1 reply
  • 1417 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
