- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi devices disconnect & incorrect password
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi devices disconnect & incorrect password
What firmware are you on?
Are you actually resetting the router or rebooting the router to get it working?
What modem is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware is 1.4.1.62_1.3.22
I have had to reboot it three times this week (turned off and back on) although on todays attempt it didn't work, now the connection to all devices is dropping probably every few hours or so. I have done one factory reset which worked for all of about two weeks, then back to this original fault. It is connected to a virgin media super hub.
thanks for the reply!
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could try downgrading the firmware a version or 2.
If you downgrade, do it over a hardwired connection, reset the router afterwards, and then manually reinstall.
I know version 1.4.1.50 got the netgear armor update and not all devices played nicely with it. If you tried that one and it has issues, try 1.4.1.42 as it was a pretty solid version of the firmware.
