Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi problems with Netgear nighthawk R7800
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-11-05
02:08 PM
2019-11-05
02:08 PM
Hello, I'm having issues with my wireless connections, 2.4 and 5 ghz. The WiFi is enabled according to the second light of the right is on. When I login with routerlogin.net I see wireless warning off. When I press on wireless i'm redirected to Advanced Wireless Settings where I see that Enable Wireless Router Radio is checked. I've set back the factory settings a few times now without any success. I've tried several firmware versions (.62 , .63 and now on .58), all with the same issues. The led light of 2.4 and 5 is off.
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-11-06
04:42 AM
2019-11-06
04:42 AM
Re: WiFi problems with Netgear nighthawk R7800
Under Wireless Settings, have you hidden the SSID? Are you using Smart Connect?
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-11-06
04:48 AM
2019-11-06
04:48 AM
Hello,
network is not hidden and smart remote is enabled.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-11-06
08:51 AM
2019-11-06
08:51 AM
Oh I'm sorry, I didn't notice that you'd posted in the wrong forum. This forum section is specifically for Netgear Nighthawk Pro Gaming routers, with DumaOS. The correct section is here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Message 4 of 4
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
