× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
With Fibre no connection Xr500
Fabi1997
Follower
My Xr500 is connected to a media converter because it's not Fibre compatible. Converter is connected with the Wan port. Do I have to change something in the router settings? Because internet provider gave me a username and Passwort for the internet. I have no internet connection at the moment 😞 I need help
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: With Fibre no connection Xr500
You need to select the login option in Settings > Internet Setup, then apply and you should get the internet.
Message 2 of 2
Discussion stats
  • 1 reply
  • 933 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
