- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Worst router ever
- Mark as New
- Bookmark
- Subscribe
- Permalink
Worst router ever
Here i am again but i'm now at a loss as to what i do with the worst router on the planet.
This product has beena serous problem and constant thorn since the day i made the mistake of buying it.
Does anyone have any advice on how i can speak to Netgear to get rid? I have dealt with loads of routers and some really great netgear products but this is terrible.
I've had enough.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Worst router ever
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, well the NetDuma operating system is frankly the worst interface i've experienced.
- Every time i log into the router i get the tutorial of Netduma.
- Sometimes the device manager loads up and very often they don't
- I very often get the R-app failed to load
- The Nighthawk app is absolutely dreadful and very unstable
I can now no longer log into the router and it appears that the only way to fix this is to perform a factory reset, which is at least the 6th time this has had to be done.
I've installed alot of Orbi routers and they are miles better than this junk which so often just doesn't keep a stable connection to the internet.
It is absolutely rubbish.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you access using routerlogin.net/adv_index.htm ? If so then upgrade there or factory reset then upgrade to this latest firmware which is quite stable based on reports then do a factory reset and see how you get on https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I bookmarked the router page. Is the only way to stop this by manually accessing each time using the IP address?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay so remove that bookmark - go to routerlogin.net or 192.168.1.1 - the tutorial shouldn't appear, then bookmark the page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, so this does seem to be a huge improvement.
There are still some graphical overlay issues but the functionality seems far better. I'll give it some testing over the next few weeks.
Whilst you're here could i maybe question you on a few of the new looking features?
The connection benchamark seems to be a useful feature but could you explain the sections?
My speed is fine with an A+ rating
the same with the Ping test at A+
but, the latency one (Ping test underload) comes back at D. Could you tell me what affect this will have and if/how i can improve this?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So Ping Test Underload indicates what your ping could be if your connection was under load from downloads, streams etc i.e. your connection was being heavily used. So that can show what your game ping could be. You can then use this test and utilize Congestion Control at different percentages to see what will lower the results as much as possible. Thereby limiting what your ping would go up to in the case of Congestion. We're still working on the accuracy of Benchmark but give it a go.
