Reply
XR 300 high MS
vally012
Follower
XR 300 high MS
Hi,
Since i have got this gaming router i cannot see my MS in fortnite on pc. At every region it just says 9999ms while if i am on my ps4 everything seems normal but then i have an other problem. If i just use my isp's modem i get around 18ms but if i connect the xr 300 to it and run everything through there with bridge mode my ms is much higher. Is there any settings i am missing or is this an known issue with the XR 300?
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: XR 300 high MS
Have you setup QoS or the Geo-Filter for the PC or PS4? The ping that is higher, is that PS4 or PC and where are you seeing this ping in the Geo-Filter or on the game and what is the ping difference?
Message 2 of 4
sammydaren
Re: XR 300 high MS
I'm a complete newbie here! Can you please be little specific?
Typhoon tv
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Re: XR 300 high MS
Have you used/changed any settings on the QoS & Geo-Filter pages on the router interface? Where are you looking at the ping?
Message 4 of 4
Discussion stats
  • 3 replies
  • 480 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
