- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR 500, EX800 AND a EAX 80?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, as the title suggests, I have a XR 500 and EX 8000, which is powering our 3100 sq ft house, but as of late, with the addition of more and more devices (Ring, soon automated lighting), I am experiencing more problems with poor wifi signal. Now, I guess I could provide a basic schematic for all of this, and will if necessary, but essentially the XR500 is upstairs with our modem, the EX 5000 is downstairs next to the garage door, which allows for coverage to our fire tv and ring stuff out and the garage, and some of the other items down stairs as well (Ring front door cam, alarm, etc.). I am wondering if adding the EAX 80 would help my problem or not. I know this is horribly general, but I figure better to start basic and work from there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 500, EX800 AND a EAX 80?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since your XR doesn't support AX modes, I would not recommend a EAX as you not be using it to it's fullest abilities.
What is the distance between the router and EX? 30 feet is recommended in between router and extenders to begin with depending upon building materials when wirelessly connected.
Is beamforming enabled on the XR router?
@fropwns wrote:So, as the title suggests, I have a XR 500 and EX 8000, which is powering our 3100 sq ft house, but as of late, with the addition of more and more devices (Ring, soon automated lighting), I am experiencing more problems with poor wifi signal. Now, I guess I could provide a basic schematic for all of this, and will if necessary, but essentially the XR500 is upstairs with our modem, the EX 5000 is downstairs next to the garage door, which allows for coverage to our fire tv and ring stuff out and the garage, and some of the other items down stairs as well (Ring front door cam, alarm, etc.). I am wondering if adding the EAX 80 would help my problem or not. I know this is horribly general, but I figure better to start basic and work from there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Beamforming is enabled and the router is my own personal one, Netgear CM 600. Wifi extender distance from router is tougher to ascertain as router is on the second floor, extender is on the first, but if I go by "the crow flies" I would say 30-50ft including going through the floor, walls, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem does not have built in wifi. And yes to the wifi analyzer and changing the channels to best suit our network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most antenna postitions should be vertical for single level homes, at an angle, about 45 degrees for multi level homes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
They are all (4) roughly at 45 degrees.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Front of the house where the Front door is and the Ring doorbell cam is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What channels are you using? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Depending upon the size of your phone, an EX7700 or 8000 maybe a good additon. The EX7700s I have works great with my XR450.
@fropwns wrote:The modem does not have built in wifi. And yes to the wifi analyzer and changing the channels to best suit our network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 500, EX8000 AND a EAX 80?
Thanks for the reply, I have already changed them to non-congestive channels. I wondering if a second extender would actually help me or not. I already have an EX8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have a EX8000 then this should be all that you need. Placement and distance will be key here. 30 feet or more is recommended in between XR and EX to begin with depending upon building materials when wirelessly connected.
You may want to move the EX around enough to maybe help cover the front door area better...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only problem, though, would be that would possibly limit its ability to reach my ring door alarm in my garage and my fire tv in there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats the distance between the Ring door bell in front and the door alarm and items in the garage?
What is the current distance between the XR and EX right now?
What is the SQ Ft of your home?
I have a 5000sq ft home and just the XR450 and 1 EX7700 is enough to cover my area. Garage included.
Something you can try and move the EX temporarily closer to the front door area and see if anything changes. You can always move it back.
IF the coverage between the XR and EX isn't enough to cover both front door area and the garage area, then another EX maybe needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"What is the current distance between the XR and EX right now?" So, it is a two story home. The XR 500 is upstairs, EX 8000 is downstairs. I would estimate 30-50 ft as the crow flies (meaning through walls and the second floor)
"Whats the distance between the Ring door bell in front and the door alarm and items in the garage?" The door bell cam to say the tv (through wall) is 30 feetish. Door bell to say the ring door alarm? 80 feet or more.
"What is the SQ Ft of your home?" House is 3155 sq ft not including the garage is about 750-800 (extended three car); so 4000 sq ft.
Let me see if I can draw this out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well for that kind of sq ft home, the XR and the 1 EX should be enough.
Relative positioning to the front door area may be key here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So let me ask this. Am I better suited to have line of sight distance to the extender? If so, I am not sure that will be possible. Still working on a mock up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Line of site is always best however in homes it cant be done in most home configurations.
Mine aren't in line of site. Just placed out at a good distances.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok looking at the pictures, seems like the XR and EX are mostly right over each other in relation to the stairs.
Is the Office on the 2nd floor over the area were the front ring door bell is? And is Master BR on 1st level under Master 2 BR on 2nd level?
Seems like you may need to move the EX farther away on the 1st level. Say into the garage area...As a test.
Modem and XR router are on 2nd story near the media room?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the office is right over the front portion where the ring cam is.
Modem and XR are together in media room.
Master bedroom 2 is partially over part of master bath.
Kinda of think of it like this: (Master bed 2)
(Master bed 1)
The only problem with moving it into the garage as a test is that the amount of available outlets in the garge is, let us say, paltry. lol.
