- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR 500 Network map not showing wired xbox one x
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried to reach out to a couple others forums on here without any solutions. The only way I can get the xbox one x to show up is either rebooting, unplugging or flushing cloud. This issue has started a few weeks ago and has not fixed itself. I cannot keep rebooting, unplugging (power)or flushing cloud.
1. Firmware is up to date.
2. XBOX is in energy mode.
3. XBOX is wired
4. My sons wireless xbox is showing in network map.
5. Turned UPnP on.
6. Owned original netduma and very familiar with routers etc.
7. Also tried deleting xbox and adding it back. Did not work.
8. Unpluging ethernet from xbox and plugging back in also did not work.
Please help me fix this.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I started this thread in January. Still not fixed. There is nothing that can be said on my disappointment with this issue. A gaming router that can see consoles and will not fix it. That is the issue. Also you lost a costumer. Once this thing breaks I am not going to get a netgear again.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 500 Network map not showing wired xbox one x
And yes I can play it online while it does not show in network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What broswer are you using? Try FF or Opera? Same thing?
Disable Instant On?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use google crome, which they recommend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you try disaling Instant On to see if that fixes the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried Opera and it did not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I think I fixed the issue for me. I changed IPV6 from auto detect to auto config. Now the xbox is showing in network map.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your ISP doesn't support IPv6 natively, you can disable it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am starting to think that it's a firmware/OS issue, I have the same issues with the device list. when the device shows offline it doesn't show up in the network traffic monitor and I suspect it won't be managed by the QOS filters either. As an FYI only 5 devices will show up on the network traffic monitor.
I went to the DumaOS forums and found many threads with this exact issue for the Nighthawk but I found a lot of the devs and admins replying to threads so you may have more luck there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
2. XBOX is in energy mode. I never had it in instant mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try Jeremy's fix by disabling IPv6?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So is the system now working with IPv6 disabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I never said I disabled it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well that is now not working. My sons wifi connected xbox is showing but my wired one is not. Frustrating to say the least.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing else is wired. I also turned off all wfi devices as well just in case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now none of the xbox's in the house are showing. Old xbox one nad xbox one x is not showing. It has to be a firmware issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its showing N/A on the network map. Good catch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ANd the xbox is on and connected to the internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
