- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR 500 Network map not showing wired xbox one x
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 500 Network map not showing wired xbox one x
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Monday, January 28, 2019 16:18:53
[DumaOS] applying qos for zone lan, Monday, January 28, 2019 16:18:48
[DumaOS] applying qos for zone wan, Monday, January 28, 2019 16:18:48
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Monday, January 28, 2019 16:18:44
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Monday, January 28, 2019 16:18:44
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Monday, January 28, 2019 16:18:44
[DumaOS] NSS delete root for interface 'br0', Monday, January 28, 2019 16:18:44
[DumaOS] applying qos for zone lan, Monday, January 28, 2019 16:18:44
[DumaOS] NSS delete root for interface 'brwan', Monday, January 28, 2019 16:18:43
[DumaOS] applying qos for zone wan, Monday, January 28, 2019 16:18:43
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Monday, January 28, 2019 16:18:41
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for sharing the logs but that all looks ok.
We will need to look into this - it's a tricky one though as we have not been able to replicate it ourselves.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could this be something with the xbox code on the console? I've seen odd issues with different xbox consoles and how they are connected and use uPnP. Depending upon which one is turned on first. Also most seems like this is a xbox issue rather then a router issue.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya I presumed. DM maybechecking ARP or HostName with Mac and IP addressing?
@Netduma-Fraser wrote:
Could be but the device manager doesn't necessarily go on ports when determining what device is actually connected
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now other devices are not showing as well. I was showing my wife what was going on and turned on the IPAD. I could connect to internet and go on sites etc but it did not show up as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also I use a SB 6183 modem arris.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, thank you for the additional info
- Mark as New
- Bookmark
- Subscribe
- Permalink
SO I am still getiing auto ping to host even though itsd not showing on network monitor/manager. Does that mean it is still working as far as netduma is concerned. Whicj I could live with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Starting to think that maybe your unit is just bad. You might reach out to NG support and ask about a RMA:
https://www.netgear.com/mynetgear/registration/login.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Icons appear on the map? Yes
Does it show it in lists when adding to Geo-Filter? Yes
Traffic Prioritization? Yes
VPN Hybrid? Yes
Device manager/network monitor? No
Does it appear in bandwidth allocation? Yes
Hopefully this helps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any new info?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think if you had a questinare to send out it might help more. ex all settings etc on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
UPDATE: Went back to XR500 V2.3.2.32 and all has been working great for 3 days now. So it does have something to do with the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also having this exact issue with my router that I purchased yesterday, that is on V2.3.2.40. I was wondering if there were any updates to this, as there hasn't been a response in some time. This is a very frustrating issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downgrade to v32...
User | Count |
9 | |
4 | |
2 | |
1 | |
1 |
