Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR 500 can't connect to server or DLAN over WIFI
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-05
02:07 PM
2020-12-05
02:07 PM
Hallo,
i have problem to access my plex server or dlan server or haxball server over WIFI.
Server is in Ethernet.
Can somebody helps me ?
Best Regrads
Nuke
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-06
04:09 AM
2020-12-06
04:09 AM
Re: XR 500 can't connect to server or DLAN over WIFI
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Message 2 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-06
12:43 PM
2020-12-06
12:43 PM
Try disabling QoS completely from the Anti-Bufferbloat menu and see if that helps at all.
Message 3 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-06
02:09 PM
2020-12-06
02:09 PM
i have in QoS Never checked
Message 4 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
06:23 AM
2020-12-07
06:23 AM
Where's the wireless isolation checkbox like on my old router?
Message 5 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
07:27 AM
2020-12-07
07:27 AM
I don't mean Never on the sliders, on Anti-Bufferbloat there is a 3 line option menu in the top left of the panel, click that and disable QoS entirely there. There isn't an option for that, if there was then enabling it wouldn't help with the issue.
Message 6 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
07:38 AM
2020-12-07
07:38 AM
It disabled!!! I'm not dump. I read many website about this. And I have a new problem also. When I share a usb over internet. The max download from the usb is max 10bits. I connected over pppoe and vlan 35 0
Message 7 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
07:57 AM
2020-12-07
07:57 AM
In WAN Settings switch NAT to open and see if that helps. Is it a USB stick or a portable harddrive? A USB stick will not be very fast.
Message 8 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
07:59 AM
2020-12-07
07:59 AM
It's a 256gb with up and down 400MB/s too slow ?
Message 9 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
08:04 AM
2020-12-07
08:04 AM
It will be faster when we go private. I give you remote access to the router 😉
Message 10 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
09:03 AM
2020-12-07
09:03 AM
How are you sharing the USB storage over the internet exactly?
Message 11 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
09:04 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
09:24 AM
2020-12-07
09:24 AM
I test it with a other xr500 new one.
Message 13 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
09:52 AM
2020-12-07
09:52 AM
Okay let us know how you get on with the other router.
Message 14 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
11:16 AM
2020-12-07
11:16 AM
I tested the New router xr500. I configrate only: QoS off. Set login and pw for inet. Vlan on 35 0. Ipv6 on auto detected. Can't connect to Server over wifi.
Message 15 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
11:18 AM
2020-12-07
11:18 AM
Server configured with upnp.
Should I buy a asus router?
Usb Share is still on 10mbits update
Message 16 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
12:16 PM
2020-12-07
12:16 PM
Use port forwarding instead for the server and see if that allows access. It could be VLAN that is the issue also, if you have another router handle VLAN does it work?
Message 17 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-08
02:00 AM
2020-12-08
02:00 AM
Hi. I set port forwarding manual on the xr500 for the Server. Still not working. I have one from sip and it works with upnp over wifi and lan.
Vlan is set for all. And could be, is not a professional answer. You don't have any idea, why this don't work.
Message 18 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-08
07:53 AM
2020-12-08
07:53 AM
That one works with the XR or WiFi/LAN? I am basing that off issues such as QoS not working well with VLAN so the optimization of VLAN and other features is not great. Hence why it could be the cause and I asked you for a way for us to either rule it out or confirm that is the problem. If I knew the exact reason immediately we wouldn't be in the troubleshooting stage.
Message 19 of 19
Announcements
