tim45's avatar
tim45
XR1000 DoS attack issues
Im having a lot of consitent messages pop up recently in the system information, my ping now spikes ridiclously (was 40-50 now 70-100) to 300+. any help would be appreciated.
logs
[Time synchronized with NTP server] Sunday, Jun 06,2021 17:06:17
[DoS attack: Fraggle Attack] from source UNKNOWN,port 443 Sunday, Jun 06,2021 17:05:58
[Time synchronized with NTP server] Sunday, Jun 06,2021 17:05:17
[DoS attack: ACK Scan] from source 104.16.248.249,port 443 Sunday, Jun 06,2021 17:05:06
[DoS attack: ACK Scan] from source 35.186.224.25,port 443 Sunday, Jun 06,2021 17:04:44
[DoS attack: ACK Scan] from source 34.120.5.221,port 443 Sunday, Jun 06,2021 17:04:27
[DoS attack: ACK Scan] from source 34.120.237.76,port 443 Sunday, Jun 06,2021 17:04:27
[DoS attack: ACK Scan] from source 34.120.5.221,port 443 Sunday, Jun 06,2021 17:04:26
[Time synchronized with NTP server] Sunday, Jun 06,2021 17:04:17
[DoS attack: ACK Scan] from source 35.244.181.201,port 443 Sunday, Jun 06,2021 17:04:03
[DoS attack: Fraggle Attack] from source UNKNOWN,port 443 Sunday, Jun 06,2021 17:03:53
[DoS attack: ACK Scan] from source 44.242.93.71,port 443 Sunday, Jun 06,2021 17:03:30
[Time synchronized with NTP server] Sunday, Jun 06,2021 17:03:17
[DoS attack: ACK Scan] from source 52.84.160.211,port 80 Sunday, Jun 06,2021 17:02:26
[Time synchronized with NTP server] Sunday, Jun 06,2021 17:02:17
[DoS attack: ACK Scan] from source 52.84.169.53,port 443 Sunday, Jun 06,2021 17:02:01
[DoS attack: Fraggle Attack] from source UNKNOWN,port 443 Sunday, Jun 06,2021 17:01:48
[Time synchronized with NTP server] Sunday, Jun 06,2021 17:01:16
[DoS attack: ACK Scan] from source 35.186.224.47,port 443 Sunday, Jun 06,2021 17:00:53
[DoS attack: ACK Scan] from source 35.186.224.44,port 443 Sunday, Jun 06,2021 17:00:34
[Time synchronized with NTP server] Sunday, Jun 06,2021 17:00:16
[DoS attack: ACK Scan] from source 52.230.222.68,port 443 Sunday, Jun 06,2021 17:00:14
[DoS attack: ACK Scan] from source 35.190.245.73,port 4070 Sunday, Jun 06,2021 17:00:06
[DoS attack: Fraggle Attack] from source UNKNOWN,port 39421 Sunday, Jun 06,2021 16:59:43
[Time synchronized with NTP server] Sunday, Jun 06,2021 16:59:38
  • michaelkenward's avatar
    michaelkenward
    Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
    Search - NETGEAR Communities – DoS attacks
    Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
    Here is a useful tool for that task:
    IPNetInfo: Retrieve IP Address Information from WHOIS servers
    Most of your "attacks" are from Google and Amazon, with Microsoft thrown in for good measure.
    If these events are slowing down your router, that may be because it is using up processor time as it writes the events to your logs. Anything that uses processor power – event logging, QoS management, traffic metering – may cause slowdowns. Disable logging of DoS attacks and see if that reduces the problem. This does not prevent the router from protecting you from the outside world.
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Pro Gaming Routers - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
    • tim45's avatar
      tim45
      I have checked the IP of a few of the reports and it seems that it comes from a Corp not like google and what not. I’ve had an IP that didn’t pop up so I was thinking maybe it is spoofed.
      I will have to try and take of the scripts when I get home from work. Appreciate the thoughtfulness of your message
        michaelkenward
        Many of those "corps" rely on the Amazons of the world for their services.
  • Great response and explanation above! There messages are nothing to worry about.
    In regards to you ping spikes, do you have both Geo-filter and QoS setup? These are the two biggest features for reducing this sort of behaviour in-game.
    • tim45's avatar
      tim45
      Yes my geo filter and QoS is set up for my needs
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        OK, I was just thinking perhaps this might have been something we can adjust to reduce these ping spikes but let us know how you get on and we'd be happy to assist further.
