× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR1000 Duma OS 3.0 Fails to load
Joe_MS_39565
http://192.168.1.1/desktop/index.html#com.netdumasoftware.desktop
Getting the following message:
"Missing JSON response."
Message 1 of 6
Guru
Re: XR1000 Duma OS 3.0 Fails to load
Did you update or send the FW file using a wired PC and web browser?
Try re-loading the FW file then do a factory reset by pressing the reset button for 10 seconds then release. Clear out all broswer caches then walk thru the setup wizard.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 6
Netduma-Fraser
NetDuma Partner
What firmware version are you on? What web browser/device are you using to access it? Does it load any of the interface at all? Good advice above.
Message 3 of 6
Joe_MS_39565
Nighthawk XR1000
FW Version: 1.0.0.58
BTW - firmware was updated months ago and DumaOS was working fine. Just suddenly stopped working.
Opera web browser - updated
Message 4 of 6
Guru
Message 5 of 6
Netduma-Liam
NetDuma Partner
This firmware was released recently so I suspect your XR1000 updated to it automatically.
Could you please also confirm if you're able to access the interface via routerlogin.net?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 966 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
