Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR1000 ETHERNET PORTS STOP WORKING
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-02
08:24 AM
2023-07-02
08:24 AM
I want to know what to do because suddenly the ethernet cable is not working, before any suggestion already i connected other router to my modem and this works perfectly but the xr1000 doesn’t work i did the master reset and when i trry to set it up pop up a message ( nothing connected to the ethernet port) something like that… what i do?
Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-02
10:05 AM
2023-07-02
10:05 AM
Re: XR1000 ETHERNET PORTS STOP WORKING
Have you tried different ethernet cables/ports on the router?
Message 2 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-03
10:27 AM
2023-07-03
10:27 AM
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Message 3 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-03
03:36 PM
2023-07-03
03:36 PM
I explained I switch it with other router and is working perfectly… the xr1000 stop working and the asus router works good
Message 4 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-03
03:48 PM
2023-07-03
03:48 PM
My setup is cm1000 modem and xr1000 suddenly stopped working i did the reset and nothing the. I connect a new router and is working perfectly…. What happened with the xr1000 i dont know?
Message 5 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-03
04:05 PM
2023-07-03
04:05 PM
If you could try with other cables and ports it's good to fully rule out whether one of those could be the cause. Can you connect to the interface via any of the LAN ports for example.
Message 6 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-03
06:21 PM
2023-07-03
06:21 PM
I tried everything i have many lan cables here that was the first step!!!! try with others cables but nothing happened…. Then i said ill try with other router and this one worked perfectly….. i want to know what to do?
Message 7 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-04
07:11 AM
2023-07-04
07:11 AM
And you tried every LAN port on the router as well with being unable to get access to the interface? Are you able to access the interface via WiFi? If so can you go to the Device Manager table view and see whether the ports are showing as connected when you have a device connected to it please?
Message 8 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-04
02:29 PM
2023-07-04
02:29 PM
The router can’t get internet the main port is not working when I connect it to the modem the light who show me is connected is off all the time… so i can’t access to the Dumaos interface… cause the xr1000 is not recognizing the lan signal from the modem cm1000 netgear ( and this is working perfectly with the asus router right now) its meaning something is wrong with the xr1000
Message 9 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-04
03:25 PM
2023-07-04
03:25 PM
The router doesn't require internet to be accessed, could you unplug the modem from the XR, connect your PC to the router via one of the LAN ports and try to access using 192.168.1.1 instead of routerlogin.net. If it doesn't work try each of the LAN ports, if it isn't working for any of them, while connected to the router via a Windows PC, open command prompt, type ipconfig press enter and then post a screenshot of the results here please.
Message 10 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-06
04:32 PM
2023-07-06
04:32 PM
I did it….
192.168.1.1 doesn’t work!!
Command prompt works i attach the img..
Message 11 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-07
07:13 AM
2023-07-07
07:13 AM
Is your WiFi connected to the XR? That's getting an IP address the XR would give. Can you access via WiFi?
Message 12 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-07
08:00 AM
2023-07-07
08:00 AM
No that was via ethernet port!! The weird part is the light who show u is connected via cable is off, non red - non white…. I will try via wifi later but whats the difference? This was ethernet cable (router main port color yellow) to pc avoiding the modem cm1000
if i setup up modem cm1000 -xr1000-pc when i try to set it up the interface show me non lan cable connected
Message 13 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-07
08:36 AM
2023-07-07
08:36 AM
The screenshot you provided there was showing that you were connected to WiFi and that it's getting an IP address from the router. Seeing whether WiFi works will be a good indication of whether the ports are broken or whether it's a general issue with the router itself.
Message 14 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-07
09:06 AM
2023-07-07
09:06 AM
Ohh ok I didn’t realized was via wifi cause i connected the lan cable and started command prompt… i thought something is wrong with the ports how i can do effective the hardware warranty? Because it broke itself ….
Message 15 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-07-07
09:13 AM
2023-07-07
09:13 AM
That depends on where you purchased from and what their policy is, you could make a ticket directly with Netgear by logging in here: http://support.netgear.com/ and they may be able to replace it for you.
Message 16 of 16
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
