- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR1000 GeoFilter "The Rapp is not loaded yet, please try again in a minute" on DumaOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been trying to use GeoFilter on my newly purchased XR1000 router through DumaOS and it will not open.
Firmware version 1.0.0.58
Any suggestions would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR1000 GeoFilter "The Rapp is not loaded yet, please try again in a minute" on DumaOS
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-rout...
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for posting this issue.
Which browser are you using to access the interface? Are you seeing the same problem in all web browsers?
If you reboot the XR, are you then able to access the interface again until the problem re-occurs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have used both Gooogle Chrome and Firefox. I have also rebooted the XR as well and can use the interface. I just cant access the GeoFilter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting me know!
So could you please go to System Information -> Installed Rapps -> Click the three line menu -> Set the number of retries to 5. After this you may want to reboot the router, then see if Geo-filter will load.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I followed your steps specifically and still not luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay I did that. I even restarted my pc. A new error message came up and said "Uncaught and Undefined", the preceded to go back to the original message. After I clicked ok, it went into and infinite loading screen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please clear your browser's cache and check if the interface can load properly? That's a bizarre issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having this exact same issue on the XR1000. I can't for the life of me access the Geo-Filter or Ping Heatmap.
I've tried Chrome, Mozilla, Brave, Edge - and nothing...
I've restarted the router, tried putting the Geo-filtering to 5 ... Nothing works...
Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you just confirm which firmware version you're running?
Have you gone to System Information -> Installed Rapps -> Clicked the three-line menu and set the number of retries to 5?
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, and if you reboot the XR, do all RApps then load properly again temporarily?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried that. Geo-Filtering has NEVER worked for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you please reproduce the error, then grab a log file from System Information and send it over so we can take a look at what the issue might be? A few users had a similar issue on the R2 and we've fixed that, so if you're experiencing the same thing we'll definitely have that fixed in the next firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If that's all there is in the log that won't tell us anything unfortunately.
I'm not sure if you noticed when you setup the XR for the first time, but it probably downloaded the latest firmware and installed it. One thing that occasionally needs to be done after a big firmware upgrade is to factory reset the router. Sometimes when there's a lot of changes between two version, it can cause strange issues like this.
It would worth trying this and checking if the issues you're having still occur after this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP?artic...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought and installed this router also... This is BS. Sending this trash back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have same issue...brand new router. I had same issue with XR500. Except it would not load other Rapps like device list or qos. It did when I first installed it. But now...nope.
The new one works for all but geofilter and heat map.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Set retry to 5, rebooted from Administration UI, waited 10 minutes....same behavior. Very frustrating. Geofilter pops up an "uncaught undefined" error right before popping up Rapp not loaded message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, I did factory reset by holding in the pin on the back...went through setup...reset router before logging into UI. Waited 5 minutes. Logged in. Still does same thing. Throws uncaught exception, then says Rapp not loaded on geofilter and ping heatmap. Everything else works fine. Even auto ping on geofilter page works. Not the other 2 boxes, though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As you're still getting the error, I believe you'll need to downgrade back to the previous firmware, then upgrade back to the new one again. That should resolve the issue for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'd think knowing this is a wide spread issue support would put out another firmware update fixing this. It's bad enough paying $250 plus for a router, but it's a whole other problem installing a router in a house with 50+ devices connected then being told you need to do a factory reboot and start over to correct it.
