- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR1000 SLOW WIFI SPEEDS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently just bought a XR1000 gaming router, after setup ive noticed i was getting 85 download which i am paying for 900 down, but getting full 24 up. Ive just set my computer up and hard wired it to the router and found that im getting full speeds through hard wire. Ive tried everything ive read about disabling QOS and having Armour disabled but yet no luck with wifi speeds increasing. I cant seem to find a solution to increasing my wifi speed one bit. Any bit of advice would be greatly appricated!
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR1000 SLOW WIFI SPEEDS
Are you using SmartConnect? Could you please try disabling that if you are and connect to the 5GHz channel, then re-test speeds from nearby the XR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What device are you testing your speeds with over wireless? Is it definitely connecting to the 5Ghz channel and not the 2.4Ghz channel?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please go to QoS and under Bandwidth allocation, hit 'Reset Allocation' and make sure that Share Excess is enabled from the three-line menu?
After that, retest your speeds and let me know if you're still having the same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
okay i tested this and i was running speeds at 550 but why isnt the 2.4 getting full speeds either?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was 'Share Excess' previously disabled in Bandwidth Allocation? If so, that's why the speeds were reduced.
What exact speeds are you now getting through 2.4 and 5GHz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
5ghz averages 500
2.4ghz averages 90
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please use a Wi-Fi analyser (there's one on the Microsoft Store called 'Wi-Fi Analyser') to look at what channels your neighbouring Wi-Fi networks are using, then adjust your XR's Wireless settings to ensure you're using the least busy channels for both 2.4 and 5. After you've adjusted this, please see if there's any improvements to your speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Remember that 2.4Ghz is limited by channel width which on 2.4Ghz is 40Mhz I believe is max.
2.4GHz AX: 2x2 (Tx/Rx) 1024/256 QAM
20/40MHz, up to 600Mbps†< This is a CONNECTION RATE ONLY. Differs from actual bandwidth speed.
Also its a 2x2 antanna MIMO configuration which also is limiting.
So wifi speeds seen on 2.4Ghz depending upon connection rate will not be as fast as what 5Ghz does.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
@Tots343 wrote:
No, share excess was not disable.
5ghz averages 500
2.4ghz averages 90
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
speeds got alittle worse by switching the the recommended channels
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the exact make and model of your modem? Is it a router/modem (Wi-Fi capable) or is it a pure modem?
If possible, could you put the XR1000 into AP mode and check whether your speeds improve? This will tell us if something in DumaOS is causing the speed reduction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What’s AP mode? And how would find that mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can enable AP mode by going to the Settings tab and follow the below guide:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
I believe you might not get connectivity through the XR in AP mode with a pure modem, but please do go ahead and try as I can't remember exactly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK thanks for confirming, apologies you needed to reset. If you have a spare router lying around, put it between the XR and the modem and test AP mode, if you don't though don't worry about it.
Out of interest, have your speeds improved at all since the reset? When you setup the router again did you put 900/24 as your bandwidth speeds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure the router isn't on the floor so it's elevated instead.
It's not on a metal surface as this can interfere with the signal.
Electrical/wireless devices e.g. headphones, remotes etc are not within close proximity >~3 feet if possible
Make the antennae look like this _ | | _
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router has been elevated and away from electroics since we started this process and also the antennas have been in _l l _ the entire time also.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please click the (i) icon next to the Wi-Fi Network on your iPhone then disable Private Address. After this, test your speeds again and see if you're able to get any better speeds.
