× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR1000 UPDATE HELP
NairoD
XR1000 UPDATE HELP
I downloaded the new firmware on the netgear's site, https://www.netgear.it/support/product/xr1000#download
but when i try to restore the downloaded file it says the file is .chk when the downloaded file i sactually .cfg file. Anyone has any idea how to fix this and have the latest firmware on my xr1000 router ?
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: XR1000 UPDATE HELP
Restoring is re-loading settings from a saved config file, the firmware update is what you want, following the link above will get you sorted
Message 3 of 4
Guru
Any progress on this?
Message 4 of 4
Discussion stats
  • 3 replies
  • 569 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
