- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR1000 dumaOS not loaded yet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi I have a XR1000 Router and when i try to log in with the 192.xxx.x.x it comes up with dumaOS not loaded yet. Can someone help?
Firmware Version: V1.0.0.64_1.0.49
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR1000 dumaOS not loaded yet
add: the router is connected to a netgear CM1000v2 modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you disconnect the power cable from the XR1000 for ten minutes, then reconnect it again and after a few minutes see if you're able to access the interface?
- Mark as New
- Bookmark
- Subscribe
- Permalink
explain to me like im a two year old what the R2 is 😂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to clear out all browser caches before entering the XR1000s web page.
Try a different browser. I use MS Edge here.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router MK83+ (Router Mode) | and RBK853 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last FW update? Don't load any saved config files from backup. Just new install using MS Edge browser?
- Mark as New
- Bookmark
- Subscribe
- Permalink
how do i do that, im not super in depth in terms of networking
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Or press the reset button in back for 10 seconds then release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i cannot login to the routerlogin.com thats when i get the error
- Mark as New
- Bookmark
- Subscribe
- Permalink
192.168.1.1?
- Mark as New
- Bookmark
- Subscribe
- Permalink
192.168.1.1
routerlogin.com
routerlogin.net
all of these lead to the dumaOS not yet loaded
- Mark as New
- Bookmark
- Subscribe
- Permalink
Press the reset button in back for 10 seconds then release.
Be sure to clear the browser cache before trying 192.168.1.1 after you release the reset button.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok... will try that tonight when i get home from class
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would disconnect the XR from the ISP modem before you reset it as well.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
as stated above im using netgear CM1000v2 modem instead of an ISP provided one
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah got cha, early here. Off to get some hot tea.
Reset should get you going.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
