×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
XR1000 syntaxerror+logs+saved settings
PapaLung
Apprentice
Ok guys, I'm honestly tired of this game I've been playing for months now. Received new xr1000 replacement router from factory. Has been in use less than 3 weeks, still getting these January 24th dated logs , factory reset only seems to erase passwords and network names, I have as of right this moment, performed 3 factory resets AND fresh firmware installations this morning to attempt to get the syntax error to go away so I can utilize the interfaces device monitor. Is there somewhere else this router saves settings ie. my pc, Netgears servers ect. that needs to be erased???? Do I need to request a different router from you guys?? Is there a better , newer version with less issues? How on earth did this router get through test at Netgear? Does anyone at Netgear actually have real-world experience using the XR1000?? I understand it's not a "plug and play" set up, but my God, if it's not one thing it's another with this model. I need some REAL help with this thing, not a factory reset not a reboot not a "we'll pass it on" with no answer for months but some actual help. So please, for the love of God, can I get in contact with someone who knows what they're actually talking about so I can fix this (now my second in less than a year) XR1000????
MY EQUIPMENT
ISP: Comcast/Xfinity 1.2 gbps down, 42 gbps up cable internet
Modem: XB8 (Technicolor, model CGM4981COM )
Router: Netgear Nighthawk XR1000 1.0.0.64_1.0.49
Message 1 of 18
Guru
Re: XR1000 syntaxerror+logs+saved settings
Are these log entries causing problems?
Not much can be done with FW changes here in the forums. This would be beyond forum help.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 18
PapaLung
Apprentice
Logs are for (in my experience) showing data and failed/completed processes by the network or router. If I knew what the logs meant, I could probably figure out the issue, but, that information far as I can tell, is non existent , hence my question. I'm not asking for new FW either, I'm asking if it's the XR1000 that's the issue and is there another more reliable option I should go to.
MY EQUIPMENT
Message 3 of 18
Guru
Please post a snippet capture of what the logs are showing. Please remove any MAC addresses before posting.
Message 4 of 18
Netduma-Fraser
NetDuma Partner
Looking back at your posts you mentioned the Jan 24th logs before and I said to change the timezone to get that appearing correctly, does that work? I can't see any previous reference to a syntax error, could you provide a screenshot of what you're seeing exactly please?
Message 5 of 18
PapaLung
Apprentice
Yes, I have changed the timezone. Picture is attached.
MY EQUIPMENT
Message 6 of 18
Netduma-Fraser
NetDuma Partner
Did that resolve the date issue then?
For the error, are you forcing a connect to the interface using HTTPS? Even if you're not specifically your browser might be, e.g. Safari does this, could you force HTTP just in case and see if the error goes?
Message 7 of 18
PapaLung
Apprentice
It did not resolve the date issue, what's even weirder is that this is not even the same router I began having the date issues with, netgear sent me a replacement and the information is the same, as well as some other settings like the "dont show this again " for the tour, it use to try and take me through it every time id factory reset but not anymore. That's why I'm wondering if there's a copy of that information being stored somewhere else and it's being applied after I factory reset and set up the router. I also just logged in using Microsoft edge, syntac error gone!!! Jan logs still there after reboot.
MY EQUIPMENT
Message 8 of 18
Netduma-Fraser
NetDuma Partner
Okay great that's progress! Change the NTP server the router is using to calculate the time/date, apply then reboot and see if that corrects it please
Message 9 of 18
PapaLung
Apprentice
I have no idea which ntp server I'm supposed to use.
MY EQUIPMENT
Message 10 of 18
Guru
Try time.nist.gov
Message 11 of 18
Netduma-Fraser
NetDuma Partner
You don't have to use any particular one, try the one above and see if it works
Message 12 of 18
PapaLung
Apprentice
Does changing the timezone on the router automatically change the ntp?
MY EQUIPMENT
Message 13 of 18
Guru
No.
Message 14 of 18
PapaLung
Apprentice
Ok, I changed the ntp, the logs under the monitoring tab show correct time and date like they always have. The logs on the system information page still show Jan 24th with incorrect time.
MY EQUIPMENT
Message 15 of 18
Netduma-Fraser
NetDuma Partner
Did you do a reboot after? Do the logs in the Settings show the correct date?
Message 16 of 18
PapaLung
Apprentice
I changed the ntp and rebooted the router. The logs under the monitoring tab show correct time and date like they always have. The logs on the system information page still show Jan 24th with incorrect time.
MY EQUIPMENT
Message 17 of 18
Netduma-Fraser
NetDuma Partner
Thanks for the information, I'll talk to the team about it, I think it will only affect the log reading given DumaOS reads it correctly on the same page
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 1037 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
