- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
XR1000 the cable modem is scanning for a downstream channel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR1000 the cable modem is scanning for a downstream channel.
Your power levels are mostly all over the place and also too high for some channels:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
I'd get the ISP to look at the power levels and bring them down a bit and also get ALL the channels on or near same power levels for each other.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Might ask for a on site visit to be sure.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had the XR500 hooked up all last night and unti 1200 EST. As soon as I plugged the XR1000 in the downstream blinked and I lost IPV6. Would like and try and figure this out but at the same time this is taking serious time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure there are no coax cable line splitters in the between the modem and ISP service box. Done
Be sure your using good quality RG6 coax cable up to the modem. I guess I need to buy one
Start with removing any amplifiers, signal attenuators, or splitters from the coax. Done
From there check the line for kinks, damage, moisture in the line. None
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do. Did not see anything. Also the XR500 is not having that issue on the same line with the same hook up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still have the ISP review the event logs page and power levels. Power is too high.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Noticed there's not been an update in a few months. Did you manage to get your XR1000 issue sorted with IPv6?
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
