× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR1000 vs XR1000v2: the difference?
ssssss
Tutor
Anyone know the difference between these two hardware versions? Thanks,
Message 1 of 7
Re: XR1000 vs XR1000v2: the difference?
Try asking in the place reserved for these devices:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Message 2 of 7
ssssss
Tutor
Message 3 of 7
Netduma-Liam
NetDuma Partner
There was an issue with supplying some hardware for the XR1000, so they had to use different but comparable hardware instead. The performance will be the same between the two, it's just a case of any new XR1000s purchased will now be 'XR1000v2'.
Message 4 of 7
Guru
Does this still use same FW code base and I presume same release FW between the v1 and v2?
Message 5 of 7
Netduma-Fraser
NetDuma Partner
Firmware is not compatible with both, there will be separate firmware versions for each
Message 6 of 7
Guru
Good to know. Thank you Sir.
Message 7 of 7
Discussion stats
  • 6 replies
  • 2337 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
