× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
XR300 Geofilter not working as expected
YD58
Hi all,
I am trying to use the geofilter on xr300. Obviously a bit tricky to understand as most things just say nil instead of an actual name for setting. I have tried to follow guides here to set up but it still connects to servers outside of my set range. Can anyone advise on how to set up properly? Image attached.
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 6
Netduma-Fraser
NetDuma Partner
Re: XR300 Geofilter not working as expected
Can only see one picture currently until it's moderated but please do the following:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager (if on PC)
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works.
Message 2 of 6
YD58
Hi, thanks for suggestion but no change in behaviour. I am going to pick up an xr500 today to try out so maybe that will work.
Message 3 of 6
Netduma-Fraser
NetDuma Partner
Did you change the PC to a PlayStation so when you add it back to the Geo-Filter it adds with the console service? As that will filter better. Let us know how you get on!
Message 4 of 6
YD58
Yeah I did try this. Even set as console it still connects to servers outside the set radius.
Message 5 of 6
Netduma-Fraser
NetDuma Partner
From your screenshot it does appear to be blocked outside the radius but Auto Ping thinks it is the host which is odd. In Settings > WAN, can you toggle the NAT option from however it is set now and try again please?
Message 6 of 6
Discussion stats
  • 5 replies
  • 1318 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
