× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
XR450 - Upload causes firmware to crash
ramsamant
Hi, I have a XR450 which crashes when I try to upload large quantity of files and/or a large file to OneDrive. This is consistent behaviour and I had to move to another room's access point which is a router of another make for my uploads to work. I was backing up about 275Gb in total and this never worked on the XR450. The router is on the latest firmware. Anyone faced this and managed to find a solution?
Message 1 of 12
Guru
Re: XR450 - Upload causes firmware to crash
How longs has it been going on?
Did you try a factory reset and reinstall (without using a backup)?
When you say crashed, does it cause it to reboot?
Are you uploading over wireless or over a wired connection?
Message 2 of 12
ramsamant
Hello, I have this problem for the past week or so, since I been trying to move my content from one laptop to another via one drive (only option for me since it is a work laptop). I got it sorted out by using a different router in my living room but still want to try to get to a stable version of FW for this XR450. I did not reset my router and have not tinkered with any of its settings or throttling etc other than putting it into AP mode.
When I say crashed, it takes out the router functionality completely, no device can connect to the SSID and a wired NVR connected to it also becomes inaccessible. I have to power cycle it for it to work again. the router homepage also becomes inaccessible.
Uploading is over wireless.
Message 3 of 12
Guru
I've seen large uploads over 5ghz cause issues on other routers but not on the XR series. Curious.
Glad you got it taken care of but still a curiosity. If you run into again, I'd try re-installing the firmware to the router and doing a factory set.
Message 4 of 12
Guru
Does same thing happen if you upload over a wired/ethernet connection?
Message 5 of 12
ramsamant
I did not try the wired connection as it is a bit of a bother due to the height of the router in my room. Have kept it away from my cats.
Message 6 of 12
Guru
Something to try when you can. They make varied lengths of CAT6 cabling. 😉
Message 7 of 12
ramsamant
🙂 I do have those lengths and will give it a shot, but this shouldn't be happening!
Message 8 of 12
Guru
How is the wireless settings on the XR router configured? Under Basic and Advanced menu please.
What is the brand and model of the wireless adapter in the PC your uploading with?
Is Armor or Traffic Meter enabled on the router or have they ever been enabled?
Message 9 of 12
Netduma-Fraser
NetDuma Partner
With it in AP mode there really isn't much you can change to potentially work around the issue. Are you using Smart Connect? Are both devices connected to the XR?
Message 10 of 12
ramsamant
Never used Smart Connect.
Both devices were connected to the XR but only the Upload was on whole the download i had not activated on the second laptop.
The source laptop was a Lenovo and been using it for five years. My newer laptop is a MacBook Pro. Both upload and download were failing on the XR for large files and large quantity of files.
Message 11 of 12
Netduma-Fraser
NetDuma Partner
Connect them via different methods so one via 2.4 then other via 5GHz or one via ethernet and see if the same happens
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1300 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
