× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 BUG
Xr500
Apprentice
XR500 BUG
  • Firmware version : V2.3.2.32
  • QoS -> Traffic Prioritization -> Selector My Pc -> Advanced -> Port Start1  End65535  Protocol TCP&UDP  ->  DONE
  • Firmware Previous versions Qos Business as usual
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 6
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: XR500 BUG
Yes thats the one we're aware of thanks, fixed in the next version
Message 4 of 6
All Replies
Netduma-Fraser
NetDuma Partner
Re: XR500 BUG
I can't see the picture but is it an error message? If so we're aware and is fixed for the next firmware.
Message 2 of 6
Xr500
Apprentice
Re: XR500 BUG
Thank you for your timely response.
Below is the details.
RPC error 'ERROR_UNKNOWN': bad argument #1 to 'len' (string expected, got nil) -> stack traceback: ?: in function <?:73> [C]: in function 'len' ?: in function '?' ?: in function 'decode' ?: in function <?:50> (tail call): ? ?: in function <?:324> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:290> [C]: in function 'run' ?: in function <?:345> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:261> (tail call): ? /dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> [C]: in function 'xpcall' /dumaos/api/cli.lua:59: in main chunk [C]: ?
Message 3 of 6
Netduma-Fraser
NetDuma Partner
Re: XR500 BUG
Message 4 of 6
Zawolfy
Re: XR500 BUG
whens the next firmwawre update?
Message 5 of 6
Netduma_Jack
NetDuma Partner
Re: XR500 BUG
NETGEAR decide when releases occur, which happens after they complete internal testing, so I am afraid we cannot give a timeline.
Message 6 of 6
Discussion stats
  • 5 replies
  • 3392 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
