Reply
XR500 - Bridge Mode Gateway Bandwidth test fail.
Steamblop
Follower
Please help, the initial setup bandwidth test never detects the speed. I have it setup through bridge mode on a xfinity gateway XB3.
Message 1 of 2
Guru
Re: XR500 - Bridge Mode Gateway Bandwidth test fail.
Besure the modem is in full bridge mode.
Did you power OFF the modem first after setting bridge mode then back on before powering on the XR router? Try this.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 2
Discussion stats
  • 1 reply
  • 994 views
  • 1 kudo
  • 2 in conversation
Announcements
