Reply
XR500 Custom VPN?
schumaku
Guru
Re: XR500 Custom VPN?
One OPenVPN config does translate to just a single active OpenVPN session - users expect more, like say a US based VPN provider for Netflix, one on a non-government controlled off-shore whatever service for the P2P hide-my-a**, ... That is what would make it truly hybrid.
Message 126 of 143
Netduma-Fraser
NetDuma Partner
That's down to VPN providers, we just provide a client that allows you to apply the VPN to specific devices/services so not everything connected to the router has to be VPN'd
Message 127 of 143
schumaku
Guru
@Netduma-Fraser wrote:
That's down to VPN providers, we just provide a client that allows you to apply the VPN to specific devices/services ...
There is nothing that stops Netduma from allowing multiple concurrent active VPN sessions to different providers or locations, and allow policy routing to different destinations.
...so not everything connected to the router has to be VPN'd
Some of your resp. Netgear customers request all traffic VPNed - they even like to see an Internet kill-switch if the VPN service is not active.
Message 128 of 143
Netduma-Fraser
NetDuma Partner
That has never been something requested from us, to allow multiple providers to be connected at once or even multiple locations. I don't think this is a use case for most people.
The kill switch is there currently. We'll likely add the ability to VPN all devices as well in the future but can still be done if all devices are added.
Message 129 of 143
jordy787
Guide
I cant seem to get ipvanish to connect under advanced on my xr500.
ipvanish config file I pasted :
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Message 130 of 143
Netduma_Jack
NetDuma Partner
Hi Jordy,
You also need the bits at the top of the config file. For example:
lient
dev tun
proto udp
remote lax-a38.ipvanish.com 443
resolv-retry infinite
nobind
persist-key
persist-tun
persist-remote-ip
ca ca.ipvanish.com.crt
verify-x509-name lax-a38.ipvanish.com name
auth-user-pass
comp-lzo
verb 3
auth SHA256
cipher AES-256-CBC
keysize 256
tls-cipher TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-DSS-WITH-AES-256-CBC-SHA:TLS-RSA-WITH-AES-256-CBC-SHA
VA==
Message 131 of 143
jordy787
Guide
So under advanced I pasted this under the config section:
client
dev tun
proto udp
remote sea-a14.ipvanish.com 443
nobind
persist-key
persist-tun
persist-remote-ip
verify-x509-name sea-a14.ipvanish.com name
auth-user-pass
comp-lzo
verb 3
auth SHA256
cipher AES-256-CBC
keysize 256
VA==
Still says status failed. Also inputted the ipvanish login email + password, still isnt working
Message 132 of 143
Netduma-Fraser
NetDuma Partner
Above the begin certificate line you need to add <ca> and then under the end certificate line you need to add </ca> see if that works
Message 133 of 143
jordy787
Guide
I added that and still says failed..hmm
client
dev tun
proto udp
nobind
persist-key
persist-tun
persist-remote-ip
auth-user-pass
comp-lzo
verb 3
auth SHA256
cipher AES-256-CBC
keysize 256
</ca>
VA==
</ca>
Message 134 of 143
Netduma-Fraser
NetDuma Partner
The config is using UDP, are you using UDP on the VPN Hybrid to connect? Also remove this line - resolv-retry infinite
Above begin certificate you've used </ca> rather than <ca> which is what you need to use.
Message 135 of 143
lmcgeko
Its April - when can i configure my EarthVPN on the router?
Key reason i bought the router is I could configure the VPN at the router level.
If it is not going to be possible, I would like to return the router.
Message 136 of 143
schumaku
Guru
Assuming also this VPN provider does allow to generate an OpenVPN config file - go to the Advanced settings on the Hybrid VPN - there you past the complete OpenVPN config file, including the (in-line) certificate http://support.netduma.com/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hyb... this is available since Hybrid VPN is available, not just since April 1st.
Message 137 of 143
jordy787
Guide
Why is it that if I use ipvanish through my router my download speed is 20mbps but if I use the windows client then its about 200+mbps?
Message 138 of 143
Netduma-Fraser
NetDuma Partner
There is a limitation when using the router, that is why the VPN Hybrid is available so you can apply it to only certain applications/services and then every other device/every other application/service on the device can run through the normal connection.
Message 139 of 143
IDdrew
Unless that is done by firewall or IPtables your protection is imaginary.  There will be packet leakage.  Also vpn use is a matter of discipline no matter what your purpose - as there are many.
the expressVPN and iVPN OS clients do this well.  Poorly done by TorGuard and most others with silliness like 'disable network interface' or 'routing to 0.0.0.0 initiated by script'
expressVPN employs an OpenSource client that is well maintained.
I endorse no specific provider without knowing employment criteria
Message 140 of 143
beec9
For Express VPN or other VPN services is it better to enable the Hybrid-VPN kill switch or the killswitch through Tumelblick instead? My focus would be the more secure and reliable option.
Message 141 of 143
Netduma-Fraser
NetDuma Partner
I would suggest the Hybrid VPN kill switch as I'm not familiar with the Tumelblick option. If you're using the Hybrid VPN then I'm not sure how selecting the option elsewhere would work.
Message 142 of 143
chaoticbeliever
Yes not all VPN providers offer muti device login. I use Ivacy VPN for browsing online and yes configuring a VPN to your router does add an extra security layer. With a VPN set up directly on your router, yours and cyber criminal's devices will automatically be encrypted, meaning that you’ll still have a certain level of safety and anonymity. This also means that no matter what the attacker may be trying to do on your network, which may be illegal in some cases, it will be impossible to trace the activity back to you.
Message 143 of 143
Discussion stats
Announcements
