× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 DFS Network Channels
Brennan73
Good Afternoon, I ran a WiFi Analyzer and it recommends that I change my 5.0GHz wireless network to a DFS channel. I know very little about these types of channels but understand there are certain rules to them. I game a lot on my computer so I want to know if there is any negative impact to switching to one of these DFS channels. Is there risk to being disconnected randomly, or anything else? Thank you for your time.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Guru
Re: XR500 DFS Network Channels
I've never had issues but I'm not a hardcore gamer, more of a casual gamer.
the wifi should switch off the dfs channels as needed but again, I've never noticed the switch.
Message 2 of 4
Guru
Some older wifi devices may not work with DFS channels are used.
36-48 and 149-165 are best to use.
Message 3 of 4
Netduma-Fraser
NetDuma Partner
There is a risk that you could be disconnected from the channel if radar is detected on that channel while it switches to another. If this happens when you're gaming then you could be kicked from the game.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1598 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
