- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: XR500 DHCP issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
NG doesn't post when FW is coming out. You'll have to keep an eye on the support download site and here in the fourms.
@COBRA00000 wrote:
When is the new firmware coming out I would like to put everything back to auto update and take off power saving etc Thanks
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Having the exact same issue; massive lag spikes on Xbox and keep losing connection. I think the issue is with IP lease from the DHCP. In CMD when I IP/release then IP/renew it fails to get another IP from DCHP and I have to reset my router; works after that.
Unfortunately there doesn't look like there's a way to set lease duration in the router settings. I will try to disable auto-updates and always-on on my Xbox and see if the issue is resolved and post back here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
im having the same problem on the xr700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Im having the same issue, set static ips and still keeps happening, is there anyway to get acess to the beta firmware to see if that solves the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try a manual FW load. You might revert back to intial shipping FW to see if the problem is seen there. Factory reset after manually loading FW and setup from scratch.
Set the Default DHCP IP address pool from 192.168.1.1/.254 to 192.168.1.100 to .200.
Try this. Ensure that your using reserved IP addresses for chosen devices ON the router. Ensure that when using Static IP address ON devices that these IP addresses are outside of the default DHCP IP address pool set on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
ive done all that. its a fw issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
usless you no something about the new FW that the netgear tec people dont, please let me no and Netgears tec people no too. according to NG its a FW issue. they couldnt get the new FW running right hooking everything up there selfs through team veiwer.they said not to use new FW. it drops the internet four 2 to 5 secs.not good for online gamming , skyping or anything live.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
sorry, I meant to be on xr700 topic!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Let us know if this suggestion helps:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@COBRA00000 wrote:
I’m still having this issue is there a fix and yes as before router has newest firmware. I’m to the point I’m looking at new routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm having the same issue. I just purchased the XR700 and thinking of returning it. Many of my devices will not connect to WiFi. Some say failed to obtain IP address. I've tried everything I can think of with no solution. Could I please try this BETA firmware? @Netduma-Fraser
My log is attached file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try reverting back ot v20 FW. Other 700 users reported having resolved problems with this prior version of FW.
Also do a factory reset after downgrading and setup from scratch.
Also set the DHCP IP address pool to 192.168.1.100 to .200.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Great suggestions from Furry. I recommend you try all of them.
Also, I assume you haven't set static IP address on these devices? If so, please set them back to dynamic
User | Count |
11 | |
5 | |
3 | |
2 | |
2 |
