- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: XR500 DHCP issue
I set static IPs for all wired devices since they were showing up in the DHCP requests to my ISP. In addition, I have a S8000 switch that was using DHCP as well and have since diabled it. I will keep you posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Same problem. .22 works but everything after doesn't. I was told a beta was coming soon to address this, can you elaborate?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Is this update going to change the terribly short DHCP lease times?
I get D/C'd every day every 8 hours because of the lease renew issue. No way to change it and if I do a release or renew it creates a temporary 1 hour lease before it renews for the 8 hour lease.
This is on v 2.3.2.56.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have a similar issue (with the newest live firmware). Static LAN IPs outside the DHCP range are still being interrupted when the lease renews.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
what happens if you downgrade FW versions?
Firmware Version 2.3.2.40 or
Firmware Version 2.3.2.32
@BPowell wrote:Is this update going to change the terribly short DHCP lease times?
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have been plagued with this DHCP disconnect issue for what seems like a year now. All of my LAN devices disconnect once a day, every day. It always happens when I am gaming, which results in a massive lag spike/disconnect. I am praying that a fix comes soon. I just want the equipment to work as it should and not have to set static IP's for every device and downgrade to unsecure firmware. I have lost a lot of faith in Netgear as a company because of their slow response to this massive issue affecting many people, on a premium product at that. Signed up for the beta, hopefully it works! I have combed through about 50 different threads and forums and seen all of the trouble that this issue has caused for so many, thanks to all those who have offered support/advice throughout.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm on my second xr700 and was having the same issue, I couldn't run the router on any FW except the OG FW it came with. after getting the new xr700 and having the exact same problem I thought there could be something else causing this so I logged into my modem [NG CM1000] and in the logs there was some problems in the logs. I also noticed the FW was not the latest on the netgear cm1000 so I call my isp and they said netgear had to fill out a FW update request form and send it in and they never did, I contacted netgear and they said they did request the FW update. so basicly I had a third party router that was stuck on old FW. I got a modem from my isp and now I can run any FW's on it without the disconnects. so was the cm1000 causing the disconnects, I dont know but it seems that way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I was accepted into the beta program but I get an Access Denied when I try to access the Beta Forum link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm having this same issue. Started after a few months of owning the router. I'm a streamer too, so having my router suddenly having these constant drops in the middle of a stream is incredibly annoying. I tried signing up for the beta, but I haven't heard back about it. Are they accepting anymore people?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi all, I am having the same issue coudlnt get ip address for android devices after a few days and have to rester my router. When this happens also cannot access the router settings very well get "The operation is taking longer than expected. Please briefly wait before using this R-App."
Just bought this 2 weeks ago!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The stock firmware is better too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I will try that but not a very happy disabling Port Scan and DoS Protection!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Well that has not worked either, now the wifi crashes while ethernet works fine and I cannot login to the router all i get it is This Rapp is not loaded yet, please try again in a minute. I have to hard reset.
Have Pm'd youy my log after hard reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Probably the best bet is to try the beta or downgrade to a firmware that may be more stable for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Any more updates on this, I am getting fed up of restarting the router several times a day and may just end up giving it back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The beta resolved this issue for me. Where you able to get the beta installed? And, did you do a factory reset after you installed the beta?
User | Count |
11 | |
5 | |
3 | |
2 | |
2 |
