- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Keeps Reseting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Internet Randomly drops out and router will reset multiple times. Any Solution for this. It seems like many people are having this issue with this router. Perhaps Restoring to a previous software will fix it? Thoughts please. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Keeps Reseting
- Mark as New
- Bookmark
- Subscribe
- Permalink
It doesn't do a Factory Reset. It just reboots itself and the power light stays on. And it will do this 4 or 5 times in a row. I do have it plugged into a power extender so i will try plugging it directly into an outlet. Internet drops on both wireless and wired connections. I have the newest firmware update installed V2.3.2.56
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am seeing the same issue with mine that is only 2 weeks old. Running firmware V2.3.2.56 and plugged into a 450VA 600W UPS by itself. It will reboot on its own and will come back after a few minutes. Wired and wireless connections lose connection and network capability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the unit is totally rebooting and not just losing connection, that would suggest a hardware issue. If you're certain it's nothing to do with the power supply, it might be worth contacting netgear support directly to ask about a replacement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Drops for about a minute and then comes back up. Usually drops again shortly after the first reboot (about 30seconds) and contuines to do this a few more times. I don't need to reboot the router it is doing that on its own. I tried the static/reserved ips in the past and that did not help. Modem still has connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So it doesn't lose power, just connection?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correct. It is not loseing power. The orange light stays lit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mean it might be losing power for a split second. I don't know how one could tell. It appears to just be reseting itself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well if you're certain that it's rebooting and not just losing connection, then it's probably a hardware issue. It might be worth downgrading to a previous firmware just to see if anything changes, but I doubt it. You can get an old one here: https://kb.netgear.com/000060464/XR500-Firmware-Version-2-3-2-40
