× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 LAN Connectivity Issues
Netduma-Fraser
NetDuma Partner
Re: XR500 LAN Connectivity Issues
So the problem definitely seems to be wifi not communicating properly with wired devices so could you make a Guest WiFi network please and enable the option "Allow guests to see each other and access my local network" and see if it works when connected to that WiFi please?
Message 26 of 36
madnz
Tutor
Hi @Netduma-Fraser ,
As per a previous post I have already tried this option, with less than better results.. Can't load anything at all over the guest network, device is shown as being connected, pings fine but no access via browser or finder. I'm absolutely dumbfounded as why it would work one way and not another. cheers.
Ping Result Guest Network.. Ping has started…
PING 192.168.1.13 (192.168.1.13): 56 data bytes
64 bytes from 192.168.1.13: icmp_seq=0 ttl=64 time=2.866 ms
64 bytes from 192.168.1.13: icmp_seq=1 ttl=64 time=2.259 ms
64 bytes from 192.168.1.13: icmp_seq=2 ttl=64 time=7.494 ms
64 bytes from 192.168.1.13: icmp_seq=3 ttl=64 time=1.461 ms
64 bytes from 192.168.1.13: icmp_seq=4 ttl=64 time=1.484 ms
64 bytes from 192.168.1.13: icmp_seq=5 ttl=64 time=1.854 ms
64 bytes from 192.168.1.13: icmp_seq=6 ttl=64 time=31.074 ms
64 bytes from 192.168.1.13: icmp_seq=7 ttl=64 time=92.866 ms
64 bytes from 192.168.1.13: icmp_seq=8 ttl=64 time=2.260 ms
64 bytes from 192.168.1.13: icmp_seq=9 ttl=64 time=1.496 ms
--- 192.168.1.13 ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 1.461/14.511/92.866/27.511 ms
Model: XR500|Nighthawk Pro Gaming Router
Message 27 of 36
Netduma-Fraser
NetDuma Partner
I'm really not sure what else I can suggest to be honest, there aren't any other settings that I could see affecting this. You said it happened after changing routers, could you place the XR behind another router but put it in AP mode please and connect to the XR via wifi and see if it works?
I'm not suggesting to keep it that way the whole time but that will essentially disable DumaOS entirely so if it's a DumaOS issue it should work, if it isn't then it won't and I'll know who to pass it on to.
Message 28 of 36
GoalTV
Hey
Anyone has found any soltution i'm running to exact same issue on my XR500
On Wired local devices loads fine on wifi it takes 10 Minutes to load a simple interface via local network.
I tired disable everything, looks like there is some kind of firewall in dumaos which we don't have access to due poor UI options.
Maybe if we could stop services manually to debug it would be better solution I also have tired upgrade to 3.0 to see if it fixed.
I did over 10 Factory Resets and issue is still there. so looks like it's some firewall which is blocking the wifi connection with wan. as it seems to work for few sec on router boot until services are loaded which we can't disable.
Message 29 of 36
GoalTV
Also forgot to mention I noticed the issue only exists on IPv4 Local if you try IPv6 Local it works fine
Message 30 of 36
Netduma-Fraser
NetDuma Partner
I'll respond to your topic over on the Netduma forum @GoalTV
Message 31 of 36
JoseExposito
Yo tambien tengo este mismo problema, ¿alguna solución?
Message 32 of 36
Netduma-Fraser
NetDuma Partner
Te he respondido en el foro de Netduma
Message 33 of 36
madnz
Tutor
No Solution, even on the beta.. Absolutle waste of money this router.. went back to my old netgear router and performs better even though its 8 years old..
Message 34 of 36
Netduma-Fraser
NetDuma Partner
@madnz sorry to hear that, Netgear have collected all the information they need from other users experiencing it so it shouldn't be long before they have a fix
Message 35 of 36
madnz
Tutor
2 Years Later.. Still no fix..
Message 36 of 36
Discussion stats
  • 35 replies
  • 4233 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
