Reply
XR500 Lan ports problem
pedro802
There is no problem with wifi, but sometimes I get disconnected when I connect ps4 with lan cable. and it will resume normal immediately.
There is no problem when I try to connect internet without router.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 6
Accepted Solutions
Netduma_Alex
NetDuma Partner
Re: XR500 Lan ports problem
Message 2 of 6
All Replies
Netduma_Alex
NetDuma Partner
Message 2 of 6
pedro802
my router's firmware version is v2.3.2.40
Is it different from what you offer?
Message 3 of 6
Netduma_Alex
NetDuma Partner
The hotfix firmware I linked you to is based on the same version, BUT it has a small fix which stops dropouts. Apart from that fix, it is the same as the version you've got.
Message 4 of 6
pedro802
i have found the situation that when i playing 11vs11 game, lan port disconnect will happen.
If there are fewer people connected, there will be no problem.
Message 5 of 6
Netduma_Alex
NetDuma Partner
That's weird. Do you get disconnected frequently when doing bandwidth intensive tasks like streaming 4K video or downloading game patches?
Message 6 of 6
Discussion stats
  • 5 replies
  • 2090 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
