- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Locks up after latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
After allowing the device to autoupdate, I have to reboot this new router every day. It just locks up, or drops the internet.
Reverted back a build and so far no issues.
Anyone have insight on this. I even updated and reset back to factory, same issue. Router seems fine on older build of firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Locks up after latest firmware
Along with this, we get pretty poor performance and lag, which has me baffled. Watched lots of videos on setup etc... Tried all kinds of things. If I just unplug the darn thing and drop back to the R8000 our internet is back happy. We never lock, we never paues, never have ping issues. Maybe I should stay with the R8000 was hoping this router would be better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.3.2.22 seems like its got some issues, and no I don't have an XBOX one connected. I do have a 360 connected to it, but no one has used it since I installed the router, don't think its even been turned on. We mostly PC based gamers and Ipad.
When it drops internet, it appears Wifi gets a little hinky as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will do, I j ust reset it back to factory again. I will apply this after lunch EST and then set it backup and send you what I have set.
Thank you, man I hope this helps. I expected this thing to kick my other nighthawks butt ;-).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Man this board software is lame the way it handles pics.
I will post them again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For some reason I could put in text at the start or the end.
MAX BW is 175 meg on a good day down
Up its 25
The average is right about where it is set.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
odd they show right above my text now. I PMd them to you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok very odd, I can see them now when I log out and back in also PM'd them to you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
IT is, and we did that last night, as we had good ping times in fortnite and overwatch but it was still jumpy. Didnt change anything so I took the router back out and we back to R8000 and life was good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then I'd also suggest doing this also: http://support.netduma.com/support/solutions/articles/16000074717-diagnose-modem-internet-service-pr...
- Mark as New
- Bookmark
- Subscribe
- Permalink
All devices are behind it, I use ping plotter a lot. I will check that article out though.
No issues using my R800 solid as a rock, only when I drop the XR500 in its place do I have trouble.
Setup a ipfence PC based firewall as a test no issues with it as well, quite impressive firewall for free QOS is not as robust as Duma though ;-).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware Version | V2.3.2.26 |
DumaOS Name | A7Legit |
After the above update was applied I seem to be much better off. I ocassionaly have a wifi device that won't attach for some reason, and gettiing new ones to join on the 5G channel 149 is almost impossible. I can join my previous router on this band with no issue. Same security etc...
As far as lockups, only had one and the router has been up for a week.
Turning QOS to Always seems to be the answer, but I wish it wasnt the solution. I would rather have the true 180 meg when no one else using the internet instead of 80% of it. Maybe there is a setting here I need to tweak as I am noonb to duma.
Brett
- Mark as New
- Bookmark
- Subscribe
- Permalink
Setting to Always is optimal so you never experience any local congestion but you could set it to when high priority detected and then based on your Traffic Prioritization settings will only apply your Anti-Bufferbloat percentages when gaming is detected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry went out of town, for the slow response.
No its all of them, something is amiss when set to channel 149, which unfortinamtely is where I need it Freq 5745.
I can try dopping it down below DFS next and see what happens I guess. But the 5745 range plus or minus 10 is clear. And while lowering it to 48 or below around 5200 I would some internal speed to my media servers.
Is V2.3.2.26 still the latest build of firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure whats up, but I get a lot of these type errors navigating the OS or just sitting on the dashboard watching whats going out the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
